Clothes not drying even though there is heat
Brand: Maytag
Model Number:MEDB835DW4
Main Symptom:Sensing not working?
What happens & when: only dry clothes on “timed dry” and varying the time. Heat is present. If on “normal” the clothes are damp at end of cycle.
Error Code (if any): none
Parts or tests already tried: none
Check your venting to make sure that it is clean and clear. This is the most common cause for this issue.
