Clothes Mover vs. Repair Kit
[SIZE=3]Good Day![/SIZE]
[SIZE=3]My clothes mover has been moving not as fast as it did in the past. So I went to take the clothes mover apart but noticed it had this screw that I did not have proper tools to remove so I went to Lowe’s to purchase an ‘extenstion’ for the socket so I was able to remove the screw. But now the Base and the Clothes mover is attached so how do I remove the clothes mover and replace it. Or should I have purchased the ‘repair kit’ instead of the Clothes Mover? HELP! Is there some special tool I need to remove the clothes mover from the base? Thanks for your assistance![/SIZE]
Very likely the problem is a bad agitator dogs, so the repair kit should fix it. The instructions are attached to the reply.
Here are the breakdown diagrams and Agitator, basket and tub replacement parts for WHIRLPOOL LSR7233DQ0 | AppliancePartsPros.com
Agitator dogs - trust washer.pdf (102.2 KB)
Will this same repair kit work on Whirlpool model #LQS9010LW2. The top agitator does not work and I don’t want to have to replace the entire assembly.
Answered here: http://forum.appliancepartspros.com/dryer-repair/74425-top-agitator-not-working-properly.html#post181578
