Clock & timer
[FONT=Times New Roman][SIZE=3][COLOR=#000000][/COLOR][/SIZE][/FONT]
[SIZE=3][COLOR=#000000][FONT=Times New Roman]Manufacturer Number 12200037[/FONT][/COLOR][/SIZE]
[FONT=Times New Roman][SIZE=3][COLOR=#000000][/COLOR][/SIZE][/FONT][FONT=Calibri][SIZE=3][COLOR=#000000]Jenn Air Range/Stove/Oven Mechanical Clock and Timer[/COLOR][/SIZE][/FONT][FONT=Times New Roman][SIZE=3][COLOR=#000000][/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]This part is not working on my range-oven. Does anyone have a replacement or repair advice? [/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]I am also looking for a manual to copy. I need only the section that tells how to clean the oven using the high temperature.[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]All advice will be appreciated.[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Thank you.[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Irene Baron[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]www.irenebaron.com:slight_smile: [/COLOR][/SIZE][/FONT]
I could use the whole part in addition to the clock and timer if that is easier to come by, used or otherwise.
CONTROL PANEL PARTS FOR JENN-AIR 88370: Range-F/s Std Ddraft Ele
:slight_smile:
[SIZE=3][COLOR=#286099][FONT=“Arial”,“sans-serif”]Control Panel Parts for Jenn-Air 88370[/FONT][/COLOR][/SIZE][COLOR=#286099][FONT=“Arial”,“sans-serif”][SIZE=3]Range-F/s Std Ddraft Ele[/SIZE][/FONT][/COLOR][COLOR=#286099][FONT=“Arial”,“sans-serif”][/FONT][/COLOR]
Hi Irene,
Unfortunately this part has been discontinued long time ago and is no longer available.
Here are the breakdown diagrams and Parts for Jenn-Air 88370 Range - AppliancePartsPros.com
