Cleaning up after Mice in Dacor Oven
I am working on cleaning up a Double Wall oven that some mice got into. It smells from some droppings as well as urine (yum). I have started to disassemble the oven and plan on removing all the insulation from the walls of the oven as well as scrub down all the metal which had mice yuk on it. I have started the process and all is going well. I wanted to know if anyone knows of a metal cleaner that would really clean the metal. I was thinking like an acid intense cleaner I could use on the bare steel. They did not get into the Upper or Lower Ovens. They only got into the inner cavity where all the electrical and components sit.
I will be replacing most of the wiring as precaution since a few of the wires were nibbled on so I will also want to replace some that as well as some of the cloth covered wiring which has pee on it.
Here are a few things I am looking to source:
  1. Where can I get the replacement Insulation for the cavity around oven. I know it need to be oven / heat rated insulation?
  2. Were can I source wire covered with heat shield / sheathing?
  3. Good Cleaners to help clean the oven to help remove the odor.
The Model is ECS227 in case your wondering.
Any suggestions?
any thoughts - BUMP
