the “clean” light has started flashing and we can’t reset it. Pressing the run button doesn’t start the washer. Pressing the cancel button gives two bars in the display panel.
Washer won’t start.
New control panel needed?
Is this a continuing problem with this model?
I reset using your procedure ans so far it’s working.
What would be the possible cause of the unit going into the flashing mode?
We had a repairman out here and he told us it was the control panel.
The correct model # GU2400XTPS3
Most common cause is insufficient incoming water temperature. It suppose to be at least 120°F
Otherwise there is something wrong wit the parts involved in the water heating process. They are" the heater, the high limit thermostat and the control board.
