Clean light flashing 7 times;
clean light blinking 7 times; replaced heating element a year ago. about a month ago dishwasher was running and i heard a strange sound. I saw smoke coming from the right front and went over and turned it off. smelled awful. when i opened it up i found a cap to a dasani water bottle was under the heating element(don’t know how it ended up in the dishwasher). So I thought it burned the element.
Replaced element again; now will not go through to the heat cycle; I know the water temp is good; tried a thermistor and that didn’t work; luckily I bought the part from you guys so i was able to return it.; have done the diagnostics with heated dry, normal and also the heated dry, sani rinse. Still can’t get it to go all the way thru.
One thing; when it does run for a while and I open it up I know the water is hot enough; the steam fogs my glasses, but the heating element is not hot to the touch.
If you have any other ideas please advise; I’m going crazy trying to figure this out.:eek:
Parts for Whirlpool DU1100XTPT0 Dishwasher - AppliancePartsPros.com
Check the hi-limit thermostat, should be 0 ohms.
If OK check white (Neutral) to P6 on the control board. Should be the heater resistance (10 to 35 ohms)
If open (infinite ohms) check that the heater element is OK.
If all OK then I would say that your control board is toast.
  4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Tech Sheet - 8557727.pdf (1.0 MB)
