Clean light blinks
My clean light keeps blinking 7 times. I have tried clearing it using normal wash heated dry, normal wash heated dry, normal wash heated dry, normal wash heated dry but it still blinks 7 times. Hitting Start does nothing but when I hit cancle the machine starts up for a minute and pumps itself out but does not fill it just clicks off. I checked the water inlet valve and there is no power going to it. I checked the float and its moving alright. I checked the float switch and it reads .4 on my volt meter when the switch is pushed. Model du1100xtpq0
Your model number seems to be missing several digits at the end of it so I cannot find the correct info for this unit.
