Is it possible to clean the drain pan on this model? The back of the unit is sealed. There is a musty smell in the freezer compartment that baking soda has not removed. The drain plug is open as water can be poured into the hole. I would like to remove the drain pan and clean if that is possible. Any instructions?
Unfortunately the drain pan in this refrigerator is not removable.
