Circuit Breaker
One circuit breaker gets hot, both CBR open after dryer w/heat runs ~10 min. Dryer will run on no heat cycle. Have not opened cabinet.
Parts for Whirlpool WED5800SG0 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram.
Could be that you have a grounded element.
Unplug the unit and both wires from the heater element.
Measure the element, should be around 8 to 12 ohms.
Then measure from each element connector to the case, both should be infinite ohms.
If not the element is grounded and should be replaced.
WED5800.pdf (260.7 KB)
