Chopper-impeller kit
Bought a 675806 (whirlpool # AP3115180) chopper-impeller kit from you folks. In the instruction sheet it shows the old service kit 675705 (see note 3) which is a throw away. There is a small rubber gasket about 1" in dia. in the old and new replacement kit. They do not reference this gasket to a part # nor does it show where it should be installed. It does not match the size of the drain cover seal or the inlet base seal according to the size grid. It would be nice if they would put a part # in the instruction kits beside the part that it is suppose to be or replacing. I could not find this small rubber gasket in the exploded view for the above model. Please show me where this goes or reference it to the part # it suppose to replace.
Thanking you in advance, Bush Rat
I have the same question. For others looking page 63 of this PDF shows a bit of a schematic: www. ************** .com /documents /dishwasher_disposal.pdf. (Sorry, site won’t let me put in the url…)
