Chest freezer leaking water
My chest freezer is cooling just fine, but 1-2 times a day it is leaking water all over the place. I’ve de-frosted it, but the problem is just getting worse. the unit is almot 10 years old, is it worth fixing? If so, does anyone know where I could start looking for the problem? I do not have the manual, nor can I find much info on the web. Help!
The water is appearing on the ground below the freezer. The freezer is currently frost-free, and the temp. seems to be staying below freezing
larena
Your freezer has a drain plug on the floor and drain goes under the freezer. Check the plug and were the drain hose goes. The problem is some were there.
