Check valve installation LG dishwasher LDFC2423W
LG dishwasher model LDFC2423W, drain water flowing back into tub. Ordered check valve part number MJX63511301 from Appliance Parts Pros. Part is unlike any check valve I’ve ever seen but same part shown on other sites including LG’s site. Parts diagrams show it like a miscellaneous part with no visual reference to location. Thus, I hope someone can tell me if this is accessible through the inside of the dishwasher in the drain area or does it require access to the bottom of the dishwasher or maybe some other location.
The check valve you ordered is not for the drain but is a disc that goes on the stepping motor to switch the water flow from top to bottom of the dishwasher. You model is not showing a drain hose check valve.
