Brand:Whirlpool Model Number:WFE710H0AS0 Main Symptom:Has two cracks in bottom pan. I ordered part#W11379357**, but I cannot find any information how to change it. It is the pan under the heating element. My element burnt yesterday, and when I was removing it, I noticed the cracks in the bottom pan. Can someone advise how to remove the bottom pan?** What happens & when:
To remove and replace the bake pan or oven floor pan you will remove the oven racks, then the oven bottom (two screws at the rear of the bottom, then lift up at the rear and remove). Then remove the element to get to the lower floor panel, this is removed by removing the screws around the edge and some in the middle. Once the screws are removed lift the pan out. To install the new one, do the above in reverse.
