Change GE Gasket?
does anyone know or where i can find how to change out the gasket between the door and the tub?its about 4" thick and goes around the space between the door and the tub?
This manual will show you how, but try to get some help as it is not easy. Also plan to use a lot of cuss words.
http://appliancejunk.com/ge/washer/31-9135.pdf
