Can't remove Dryer timer knob
[LEFT]Trying to remove timer (part #3-05207-1) but cannot get dial knob off on Maytag DE612 dryer. Tried prying but didn’t budge - afraid of breaking it. Is there some secret to this or is it just stuck?[/LEFT]
I could not find a breakdown for a DE612 but following is for a LDE612.
They should be the same.
Parts for Maytag LDE612 Dryer - AppliancePartsPros.com
Look at the Control Panel Parts section.
It looks like the center of the knob pops off and then you have to remove a nut that holds the knob onto the timer shaft.
[quote=denman;780925]I could not find a breakdown for a DE612 but following is for a LDE612.
It looks like the center of the knob pops off and then you have to remove a nut that holds the knob onto the timer shaft.[/quote]
Bingo! I had removed the stick-on disc in the center of the knob and found solid plastic. Looking at the parts photo for the timer shows a threaded end on the shaft. I went back and realized there is a removable cap in the center of the knob (well disguised) that gives you access to the nut. Thanks for the help!
