Can't get the error code 910 to go away, oven door lock won't reset
Brand: G E
Model Number: JGB660YP1FS
Main Symptom: keeps flashing error code
**What happens & when: reset?**r\
910 is a door lock failed to move to desired position code. If that lock isn’t resetting then you probably have a bad lock assembly AP6040143.
https://www.appliancepartspros.com/ge-latch-automatic-wb10x24780-ap6040143.html
