can't find pump filter?
been searching this forum and there is a ton of great info. fist thing I learned is my washer is a Frigidaire w/ GE logo, LOL.
anyhow, like many others, was experiencing the soaking wet clothes after the cycle was done. removed front kick panel, and see nothing resembling a drain plug of any kind. where in the world is the pump filter/drain I’m supposed to look for?
Take a look at this diagram. Part 341 is the trap that is right before the water pump. it might have stuff stuck in it. Tub & motor replacement parts for General Electric WSXH208A1WW Washer | AppliancePartsPros.com
Hope that helps.
thanks, was looking for something like this: YouTube - Washer Problems Washer Won't Drain
but I guess I’m not so lucky!
how do i even access the part you pointed to?
I would say that you’ll have to remove the back panel. The you should be able to get to the parts.
