Cannot put in Diagnose
First off, I can only put the washer in Heavy or normal cycle. I cannot use in Delicate / Rinse and Spin / Drain and Spin / or Clean. As soon as I push the selector switch past Normal to Delicate, it cancels and the wash lite comes on then beeps 3 times waits about 10 seconds then beeps 3 times again then repeats continually. I Cannot put in Diagnose mode.
Normally when this happens the main control unit must be replaced. Try it and see if that fixes things.
It is an expensive part, so if you buy from this site and the part does not fix the problem you can return it.
Thanks, I will try, but which board? I would think W10212764 the console control board Is that right?
Those of us who reply on this site are volunteers and not part of APP’s parts operation. I suggest you call in the order, and have both your model number and the serial number and they should be able to get you the right part. They are very good at this.
Good luck.
