Cancle /Start button not working.You can push the button & the Normal Wash & Washing lights light up but dimmly & go out when releasing the button.Would that be the control board?.I already removed the back panel on the door.Everything is dry.Disconnected all the connectors & the ribbon connector and everthing look fine.Any other suggestions?Thanks for looking at my post.
Wish I had some info for you, mine is doing the exact same thing. I had the “brains” replaced about two years ago. Even then, it never really worked the same as new. Now, it seems to have stopped working completely. Did you ever find a resolution?
