Can t see temp light
I HAVE A KENMORE GAS RANGE AND IT HAS THE DIGITAL CLOCK AND THE OVEN TEMP IS VERY HARD TO SEE WHEN I NEED TO SET IT. iS THERE A LIGHT BULB YOU HAVE TO REPLACE , I CAN NOT SEE ANY HELP FOR THIS IN MY OWNERS MANUAL
Champu,
No, it’s not a simple as a light bulb replacement.
If anything, it would be a bad digital display board, and or a weak low voltage control transformer.
A model number would help us to be more exact in the testing and parts you may need.
Thanks,
model # to kenmore gas range is 665.72004101, I did check for the control panel and would $150 to replace it, and I am not putting that out, Just because I temp control to really dim. Carol
Champu,
Thanks, for the model number, it was really helpful.
Based on the wiring diagram, you’d need a new electronic control board.
I’ve attached the part information, should you change your mind, about repairing the range.
AP3180904
Good Luck,
