Can I Use A New GE Compressor To Replace Bad In SubZero
My refer compressor burnt out. I have a brand new kit but it is a GE part wr87x10095 compressor. It is the same size and shape of the sub zero one. Can it be used to replace mine and/or what specs must I compare to be sure it will work properly as a replacement? THANKS IN ADVANCE.
It’s possible to use that other compressor if it is the same size process tubes are on the correct side and it’s the same amps and everything.
[COLOR=red][/COLOR]
[COLOR=red]Although you do have to have it changed by a EPA certified tech, unless you happen to be one don’t try it. It’s a hefty fine![/COLOR]
[COLOR=#ff0000][/COLOR]
[COLOR=black]Nat[/COLOR]
