Brand:Bosch
Model Number:HSLP751UC/04
Main Symptom:Communication erro E005
Error Code (if any):E005
Parts or tests already tried:Flipped circuit breaker off overnight, on next morning no effect.
Brand:Bosch
You will want to check to make sure that there is no issue with the wiring between the display and control board. If the wiring is good then check to make sure that there is proper voltage from the board. If there is not proper power then this will be a faulty board. If this is ok then the display board would be the issue.
