Can I change out the Freezer door, (without ice maker), with a door with ice maker?
Monogram 42” refrigerator
Modle ZISS42NXBSS
Serial RT030350
Where to buy?
Thanks, Patrick
If you were lucky enough to find all the required parts it would be possible but will be a lot of work and very expensive.
If you search AppliancPartsPros for ZISS42 and then look at units ( in the Matching Model Numbers section) that have a different letter than N as the next digit you will see that some of them do have in door ice makers but parts are missing prices etc. which usually means they are not available.
