I need to replace an 8 inch surface burner. It is a dual element. Each element is 3 turns.
Thanks in advance
Thanks in advance
Do you have any numbers from the original part? It should start with “WB”.
Stamped into the element supports is the following:
A66
230V/2050W
250V/2300W
SYM 661367
Made In The USA
Hotpoint
Looking down on the stove there is a center piece stamped “Hotpoint Calrod”
Also it is a 3 wire connection, if that helps.
that’l work
Thanx
You are welcome.
Gene,
I have an older hotpoint oven model number 109rf1 built in the fifties(I think). The part number AP2634795 appears to be the same element that I need after removing the old element with the chrome ring attached. I also want to replace both 6 inch elements as they work ok but the chrome ring is really tarnished and scratched. I can send a picture of the old element, but it looks identical.
Let me know if you concur that this is the correct element and if you have the 6 inch replacement elements also.
check6jetpilot
Thanks…I’ll give these a try.
