Café Fridge Convertible Door Panel Won't Work
Brand: GE Café
Model Number: CQE28DM5NBS5
Main Symptom: Door Panel Doesn’t work to change modes
I have neighbor with a Café door. We moved a couple weeks ago. When moving, one of the moving guys had to remove the doors to get it into the house. Since then, the convertible door doesn’t work. The convertible door has a panel that allows the user to change that section to cooling, refrigeration, or freezing. This model has the double French door on the bottom. The left bottom is persistently cold and the right side converts. The panel on that door does not light up nor does it allow you to change modes.
I have the app, and when using the app, I can see if that door is open/closed - perhaps that is a different sensor. An appliance guy ordered a part in the panel, and it isn’t working. He said that he can order a new door, but it’s a gamble if it’ll fix the problem.
I can’t seem to find a manual, video, or any other resource that shows how the door connects, how it functions, etc.
Any help is appreciated.
This is the mini manual.If you have GE factory service where you live I would call them!
31-1000406 GE CQE28DM5NBS5 Refrigerator Mini Manual.pdf (350.2 KB)
This is the service manual for your model:
31-9342-1.pdf (4.8 MB)
