Cabrio - UL and loud roaring noise
Hi, I have a Whirlpool Cabrio (WTW6600SW0), almost e[COLOR=black][FONT=‘Verdana’,‘sans-serif’]verytime it spins at the end of wash cycle, it gets the off-balance code (UL) on the display and it quits spinning. I have to adjust the clothes in the tub to try and make it work, it has been doing this for about a month as well as making a loud roaring noise during the spin cycle. It also sometimes makes a noise when it first starts that sounds like something hits the side of it. This doesn’t happen everytime but more times than not. Any help would be greatly appreciate.
[/FONT][/COLOR]
Probably need to replace the suspension rods. This is a common problem with this washer. Here’s a video on how to do it. The roaring noise is likely bad bearings which could also be causing the unbalance problem. See here for more info.
Eric
Thanks, I’ll take a look at the links. Is it a fairly easy fix? I’m not afraid to try just don’t want to get in over my head. :slight_smile:
