My dryer will not heat. Have replaced the heating element and the thermostat. ![]()
Replacement parts for WHIRLPOOL WED6400SW1 29" ELECTRIC DRYER | AppliancePartsPros.com
Here is a service manual.
Whirlpool 8178584 Cabrio Dryer Service Manual - ApplianceDigest.com
The first thing to check is the power.
The motor will run on half the line but the heating coil requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
