cabinet removal
My washer shakes uncontrolably even empty It is level both ways and on a solid floor. I cant figure out how to get the control panel or cabinet off to check springs snubbers etc Thanks for any help you can offer
The parts diagrams on this machine show it coming up as a basic Whirlpool Direct Drive washer.
These photos will show you how to take off the cabinet. It may be that instead of screws holding the console down you have clips which will have to be released by sliding a think metal blade under the console at each edge.
Kenmore top loader blues (SublimeMasterJW’s Appliance Advice)
I would check the springs and you should consider replacing them even if they look ok, as they can be bad but in a way not noticeable to the naked eye.
Good luck.
