Buzzing when door is closed
Brand: samsung
Model Number: ME20H705MSS
Main Symptom: BUZZING sound when door is closed
What happens & when: buzzing sound when door is closed. I replaced door latch with recommended part from your company. Sound continues
Parts or tests already tried: replaced full door latch with AP5586792 (DE96-00414D). Buzzing still continues
Hello, does it only buzz when it is running?
Correction, it buzzing even when it’s not running
That may be the relay on the control board.
How do I check or what part is recommended to replace
Find the control board, plug it in, and locate the buzzing noise; it will be obvious if that is the part. If the noise is coming from the board, replace the board. If the buzzing noise is coming from somewhere else, keep digging until you locate it.
Can you provide the control board part number
https://www.appliancepartspros.com/samsung-assy-pcb-main-de92-03624c-ap5967466.html
