Buzzer won’t work on my GE dryer even after replacing
Brand: GE
Model Number: DBXR463ED2WW
Main Symptom: dryer won’t buzz
I replaced the buzzer on my dryer and it still won’t buzz at the end of the cycle. Everything else works fine. I made sure the wires aren’t damaged and that the terminals are snug
Parts or tests already tried: new buzzer
If your GE dryer still doesn’t buzz after replacing the buzzer, the problem likely lies with the timer, as the new part isn’t receiving the signal or power, so check for loose connections, corrosion, a setting that disables the sound, or a defective timer.
