I need a new turntable motor for my Sharp microwave. Here is the specs on the one that is installed.
SM16 FY26M2H3 p/n RMOTDA252WRZZ, superceded by RMOTDA264WRZZ
120V, 60Hz, 3 RPM, 2.1W
I’ve found an exact p/n replacement for $26, but there is one on ebay that has similar specs. Here are the details.
ST16 KX63MPAQ p/n RMOTDA211WREO
120V, 60Hz, 3 RPM, 2 W
My thinking is as long as the shaft matches up with my turntable and the wattage is at or less than the original, then I should be okay right?
