Burnt wires on bosch dishwasher
The bosch dishwasher model SHU9915UC11 would not turn on again. This problem is has happened before. The white/common wire is burnt in the junction box. Once repaired (removing burnt wire portion and installing new wire nut) the dishwasher works fine for a peorid of 4-6 months then the same problem happens again. What might this real problem be. Thanks Pete
Hi, Pete.
You definitely has a good one.
Check couple of things. May be the reversed polarity at the junction box or copper to aluminum connection.
Make sure that the wire nut is correct size and tightened good.
There is one more thing: check the power cord plug for brakes and/or discoloration. You may need to replace wall receptacle and power cord.
Thank you. Post the results.
[quote=Simon / APP Team;704443]Hi, Pete.
Thank you. Post the results.[/quote]
Simin, The washer is direct wired on dedicated circuit, the wire nuts are sized right (orange). Do you think it might be a control module?
Here is a post that I found…
Model SHX56C/23 BOUGHT NEW 1/07 15 MONTHS LATER WOULD NOT START.4/08, REPAIRMAN CAME OUT AND FOUND BURNT WIRES IN J.B., REPAIRED DAMAGED WIRES. LESS THEN A YEAR LATER, IT WOULDN’T. I FOUND THE SAME PROBLEM- WIRE BURNT IT J.B. I REPAIRED THE WIRES MYSELF. THEN CALLED A REPAIRMAN THAT WORKS ON BOSCH APPLIANCES AND HE CHECKED THINGS OUT AND CAME UP WITH THE SAME THING THAT I THOUGHT.FEED WIRES GOING J.B WHERE 3C/16. WIRES WHERE TO OSMALL. IREPLACED THE WIRES WITH A 3C12. SHOULD THIS CORRECT THE BURNING WIRE PROBLEM? A FRIEND OF MY TOLD ME HE HEARD OF ANOTHER BOSCH WITH THE SAME PROBLEM THAT I HAD. EXCEPT HIS WIRE WAS A 3C14. THERE IS A RECALL BUT NOT MY MODEL ON FIRES IN BOSCH DISHWASHER
Read more: http://forum.appliancepartspros.com/dishwasher-repair/29617-bosch-dishwasher-burnt-wires-j-b.html#ixzz1qPi39oOL
It does not take fuel for your Wow cataclysm release economic system. The idea will keep you jogging simply by offering fresh gear, enchants, creams, gemstones, mounts, and so forth. However have you got ample? Are your Incredible Platinum Creating methods maintaining an individual prosperous as well as content, or even do you think you’re just barely holding your brain over h2o? Well listed below are 12 Whoa Platinum making suggestions that are likely to generate a little extra revenue to provide you with that will added a little breating room, and permit you to in fact enjoy playing your game. In fact, as soon as a person reach amount 50, there is not anyDiscover More cause you shouldn’tCheap Tera Gold possess 20,1000 goldTera Gold saved.
