Burner turns off after few seconds
Brand: Whirlpool
Model Number: WFE51S0EW0
Main Symptom: The burner turns on but goes off in few seconds
What happens & when: The burner was not turning on, hence I replaced the element switch & now the burner turns on, but after few seconds it loses heat & turns off, if I turn the switch to 50 % it on’s for few seconds & turns off, when I increase the switch again to 100% it turns on, but turns of again after few seconds, what could be the issue ?
it is faulty switch or the something else ?? pls respond
Which burner is this happening with and what part number was used for the replacement? Also, just to verify, is the model number WFE515S0EW0?
