Burner pops and flickers
Brand: GE Cafe
Model Number: C2985SET7SS
Main Symptom: Burner Pops
What happens & when: Range runs on propane and front right burner pops and flickers when it is on. I have cleaned all four jets and cleaned the cast burner. I believe the next step would be to replace the burner. Am I missing something?
Error Code (if any): None
Parts or tests already tried: Cleaned jets. Disassembled and cleaned burner.
I wouldn’t replace the burner just yet. Since this C2S985SET7SS is running on propane and only the right-front burner pops and flickers, I’d first concentrate on the burner cap/head seating and that burner’s LP orifice. GE specifically notes that an incorrectly seated cap, clogged burner ports, or an LP conversion issue can cause an uneven flame.
Try this before ordering parts:
  • Swap the burner cap with another identical-size cap, if possible. Make sure it sits completely flat with no rocking.
  • With everything cool and the gas off, inspect every small opening around the burner head. Cleaning the jet alone doesn’t rule out a partially restricted burner port.
  • Inspect the LP orifice/spud underneath the right-front burner. Make sure it’s the correct LP orifice and hasn’t been damaged or enlarged. The parts listing confirms this model uses an LP conversion kit.
  • Light the burner and compare it with the others. A normal LP flame should be mostly blue; some yellow tipping can be normal. If the flame is lifting away from the burner, fluttering, or popping, that suggests the gas/air mixture or pressure is wrong rather than simply a dirty burner.
Because the other burners work normally, house LP pressure/regulator trouble is less likely, although it shouldn’t be completely ruled out.
If the cap is seated correctly, the correct LP orifice is installed and clear, and the burner ports are completely clean, then replacing the right-front burner assembly would be a reasonable next step. I’d do those checks first so you don’t replace a good burner.
