[FONT=Calibri][SIZE=3][COLOR=#000000]I have a Whirlpool Stove RF386PXG0 and the 1200 watt front right burner is not working . One day my daughter was boiling water and forgot the burner was on. From then the burner has not worked. I have check with my Ohm meter the other burners at the place where they the wires go into the element. When I turn on the burners that work the all have power at the element however the burner that is not working there is no power at the element when I turn the switch on. Would it be the Limiter that is bad, or could it be the element? If it is the limiter, can a person purchase a new limiter and insert it into the element? How hard a job is it? It looks simple! Does the limiter slide out and slide back in? If you could help me with this I will be buying the parts from you.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]Thanks, Steve[/COLOR][/SIZE][/FONT]
Replacement parts for RF386PXG0 models | AppliancePartsPros.com
Here is a manual on how to
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/5feedbe46138625985256aa1005ef62c/$FILE/8178042.pdf
I do not work for AppliancePartsPros and could not find an exact match to your unit, may be best to give them a call to ensure you receive the correct part.
Thanks for the help, appreciate the site
