Burner not Igniting
Brand:Bosch
Model Number:NGM8655UC/01
Main Symptom:Burner not igniting
Hi, I’ve attached some steps you can try to help get you back on track and cooking again.
Before starting, make sure all burner knobs are OFF, let the stove cool completely, and unplug the stove. If you need to lift or remove the cooktop itself, shut off the gas supply first as well.
Remove the burner grates and lift off each burner cap. Before removing the burner heads, take a quick picture so you know exactly how everything sits. Most burner heads lift straight off, but if yours is held down with screws, remove those first. Do not force or pry the burner head, because you can damage the igniter or gas components underneath.
Clean around the white ceramic igniter and metal spark tip with a soft, dry toothbrush. Clean any grease or food from the burner ports, especially the small openings closest to the igniter. Be careful not to crack the ceramic igniter or enlarge the burner holes.
Once everything is completely dry, reinstall each burner head in its original position. Make sure it sits flat and properly aligned around the igniter. Reinstall any screws you removed, but don’t overtighten them. Then place the burner caps back on and make sure they sit flat and centered.
After everything is correctly assembled, restore the gas supply if it was shut off, plug the stove back in, and test one burner at a time. If you smell gas at any point, turn everything off and do not continue testing.
Then follow the troubleshooting sheet I attached and let us know what happens, especially whether each burner is sparking and lighting normally.
