Burner light
the burner light on the left side is on the burners are off. the indicater light never go off.:confused:
Hello,
Unplug the range. Remove the rear control panel cover. Remove the wire from the L1 terminal on each of the left side switches and check for continuity between the L1 & P terminals on each switch. If it reads continuity, replace the switch.
[quote=Gene;805430]Hello,
Gene.[/quote
