Built in Range
My range won’t get hot. All the controls work, the fan works but neither of the elements will get hot. What would be causing this?
Replacement parts for WHIRLPOOL RBS245PRB00 24" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN | AppliancePartsPros.com
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
The control etc. run off of 120 volts but the elements require the full 240.
L1 to L2 should be 240 volts.
If OK
If OK
[COLOR=“Red”]Be careful as 240 volts is lethal !!! [/COLOR]
I would do the following before checking the power with a meter as you do not have to mess with 240 volts to check it.
You will see that there is a Oven Shutdown Thermal Fuse in the oven element circuit. This may have blown. I believe it is Item 37 in Section 1 of the parts. Turn off power to the unit and check it with a meter. It should be 0 ohms.
Be sure to disconnect at least one side of any device when measuring for resistance. This prevents you from reading a an alternate/parallel circuit path.
If it is blown you may want to check that the fan runs and that the temperature sensor in the oven is OK. Also look at the elements for any sign of damage.
Below is a good link on the sensor.http://www.applianceaid.com/elecrange.html
Check out 7,8, 20 and 21.
They do blow on their own often after a long self-clean cycle but it is best to check the above just in case there was another cause.
If you go to the Whirlpool site there should be install instructions that will help pulling the oven out.
RBS245.pdf (387.9 KB)
