Oven wont stop at temp. setting.Just keeps getting hotter.HELP.It
s cookie baking time Lady Di
Does it stop somewhere or it’s heating nonstop?
The model number you provided is incorrect. Verify and repost it, please.
[quote=Gene;8119]Does it stop somewhere or it’s heating nonstop?
Gene.[/quote]
I set it at 300–checked the temp. with an oven therm and it was 500.I turned it off.
Model # says AO27-SB or DB
S/N cooo5717-1595
Model code-73B11
Appliance manufacturing #P8554707S
Hope you can help:)
Is it a single or a double oven?
If it’s a double oven, which oven is having a problem?
Single oven.
The problem with your oven is a bad oven thermostat.
Unfortunately the part is no longer available.
