A few days ago I noticed that my refrigerator stopped working completely. I took the back panel off and replaced the overload/start relay thinking that would correct the problem however when I plugged it back in it did not work. I am thinking though highly unlikely that it maybe the compressor. Do you think there is a reset button on this model and how do I check to see if it is the compressor or not?
Also, I noticed that the cooling fan does not work. Does this have anything to do with the relay or is this a separate issue?
Any help would be greatly appreciated
Thank you,
