Dear Sirs,
I have just broken the internal glass panel on the above GE oven. On the door itself it quotes a replacement part of 326B1016P001 but I could not find this part on your web-site. The nearest component I could find was AP2033716 which was for the Model Number JTP44GV2BB (no ‘O’ in this model number).
I am not sure which part needs to be replaced, but suffice to say it is the internal glass pane which has cracked.
Can you please advise on which component needs to be replaced and whether this can be done as a DIY job or whether I need to get a professional in to do the job.
I attach a couple of photos of the crack itself in the door along with the door component part number as shown inside the door itself
Many thanks
Steve Blackman
Broken Oven Door 2.pdf (110.6 KB)
