Tempered glass broke while sitting on rack of my Sears Kenmore Elite dishwasher. All visible pieces were removed by either hand or shopvac. However, small pieces fell into holes on bottom and are not reachable. Any suggestions about removal or is it safe to run dishwasher as is. Thanks for any help.
It’s better to remove the top pump parts off of the pump and check inside. The instructions are attached to the reply.
GU1200XTKQ0 tech sheet.pdf (1.1 MB)
Gene: Your information and attached instructions were very helpful. However, the complexity convinced us to use a professional. After observing him do the work, this was the right decision. Thanks.
You are welcome. Any time you feel not comfortable to do anything yourself, you have to have a pro to do it for you. It’s a smart decision.
