Broken door spring?
When door was opened, heard a loud snap, and all the tension is gone from the hinge/spring. HELP.
Replacement parts for KUDS01FK models | AppliancePartsPros.com
Sounds like a cable may have snapped, see Item 24 in Section 7.
You will probably have to pull the unit out from un der the cabinet to get at them.
The following may help
http://appliancejunk.com/forums/index.php?topic=2123.0
http://appliancejunk.com/forums/index.php?topic=1540.0
[quote=denman;225816]Here are your parts
http://appliancejunk.com/forums/index.php?topic=1540.0[/quote]
Thanks much–that worked perfectly–part was about $14–my daughter just had the same thing happen to her identical make and model–she hired it done–over $200. Yikes and ka-ching. Thank you again.
