Broken dishwasher
My disherwasher stopped working. the control panel has no lights and nothing works. I verified there is power to the unit. I replaced the latch and switch assembly. That did not solve the problem. any ideas?
Remove the toe panel and check the power cord connection to the dishwasher.
Here are the breakdown diagrams and Replacement parts for MAYTAG MDB5600AWB | AppliancePartsPros.com
I had a similar problem with my Maytag - No lights on the control panel; nothing worked. First, I checked that power to the door latch was OK. Then I thought the problem was the door latch switches, but it wasn’t. The problem was that one of the connectors on the control circuit board had become loose. The solder connection was broken. This connector carried power to the circuit board from the door latch. I re-soldered the connector to the board (make sure the power is OFF first) and that solved the problem. Check the connectors on the circuit board and make sure the contact is good.
