Broken cycle selector knob!
:eek: Cycle select knob broken, fell while repairing washer..
Can you post the model number and tell us exactly which knob is broken.
You can use your model number to get to an exploded view of your machine.
Model number: ras7133rqo and it’s the cycle select knob (largest button on the washer to the right)
Ok, assuming you did not break the shaft of the timer, if you will take off the back of the console you will see a white tab on the back of the timer.
Release it and the old timer knob should come off. You can order a new knob from this site, using your model number.
