Broiler works but oven wont
my oven wont work any ideas on what causes this the broiler works fine
Check if there is 120 VAC to the Bake igniter while the control calls for Bake.
If there is proper voltage, replace the igniter.
If there is no proper voltage, the control board is the culprit. Unfortunately this part is no longer available.
Here are the breakdown diagrams and Gas controls replacement parts for MAGIC CHEF 34MA-3TKXW Range - S/c F/s Gas | AppliancePartsPros.com
broiler will get hot when on broil. oven when turned on will cycle on and off it will get hot very slow. the bottom element will not get hot top element will get warm
Answered here: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/91393-magic-chef-oven.html#post211759
