Broiler delayed ignition
Brand: GE
Model Number: PGB908SEM1SS
Main Symptom: Broiler delayed ignition
What happens & when: When i turn on broiler hi, it takes about 3-4 mins for the gas to light. I hear a slight puff when it lights and a small gas odor that dissipates.
what exact parts(s) do i need to order to fix?
is there a description of the replacement process?
This is commonly caused by a burner jet being clogged or the igniter not being aligned to the burner properly. If the burner tube is thoroughly cleaned, does the problem persist?
I took a pic before i did anything. See attached. All appears aligned. I then disconnected the two screws holding the igniter. There is a large hole that appears to not be normal. See attached pic. I cleaned all holes with a paper clip. Then reassembled. Problem still exists. Please advise.
The large hole is definitely going to be an issue since it will affect how the gas flows. It could possibly be causing the gas to not hit the igniter. GE WB16K10035 Range Gas Range Bake Burner Assembly With Igniter | Genuine OEM Part
