Bought a control board and didn't come with how to program
Brand:ge
Model Number:GTW680BSJ2WS
Main Symptom:how to start over on program
Hi BigMikAnthony,
Sorry that happened. Here’s the tech sheet—I hope it helps with troubleshooting and getting the issue sorted out
YTW4514PNDG 31-3000374 (1).pdf (322.5 KB)
I did the procedure and put it on 2 but don’t know where to go from there and after that it goes to 6 so this is weird
Hi BigMikAnthony,
Try using this installation guide. Text the word PARTS to 36543GE and it will send you a PDF document containing the installation instructions and the required personality code for the replacement.
One more thing do hot and cold water line need to be connected
