Magtag micowave mmv115bab isn’t getting any power and stuck at 0
Hi.
Do you mean that display shows “0” and you can not change it, because non of the buttons works?
If that the case, you most likely should replace the Touch Pad / Membrane
Here are the breakdown diagrams and 03-Control Panel / Door / Vent Grille parts for Maytag MMV1153BAB - AppliancePartsPros.com
Post the results.
Simon.
