In order to get the bottom spray assembly removed from the bottom of the tub, is the means of disconnection located beneath the tub or is there a way to remove it from inside the tub?:o
Nannarb,
You can remove the spray arm assembly from inside the tub assembly.
Remove the lower rack,
You need to grasp the lowest section of “hard” plastic cylinder closest to the filter, and turn counter clockwise(to the left) several revolutions(4 or 5) and tug up on the assembly, and remove,
(click on part number for more information/pictures)
Reverse procedure to install new part and test unit for operation.
Dear Friend,Welcome to ugg,ugg boots,cheap ugg boots,ugg boots online,wholesale ugg boots-www.sheepskinwinterboots.com !As Christmas/New year holiday is coming, we found ugg boots has a large potential market. Many customers are buying them for resale on ******** or in their retail stores because of its high profit margin. We have a large stock of newest 2010 ugg boots,classic 5815,5825,5854, Bailey button 5803 and other fashion styles. Please visit our website: ugg,ugg boots,cheap ugg boots,ugg boots online,wholesale ugg boots-www.sheepskinwinterboots.com to order online directly!
